Lindo
ELS Real Bull mini lathe
I have successfully installed an ELS system onto my mini lathe.
Feed, taper turning, threading.
Using the Arduino based 2560
I also have the Russian spreadsheet to assist in the introduction of new threads and feeds and tapers. fantastic.
Question, is it possible to include a surfacing function ?  similar to the threading auto cycle,
Example, I need to remove 10 mm dia off bar stock, 100 mm long.
Select off a menu, depth of cut, feed per rev,number of roughing passes number of finishing passes
I can post my current Arduino firmware if needed.
Thank you
John
Spain
Hola!
I don't think that the Russian are familiar with this CNC system.
Для тех, кто ничего не понял:
ELS system - какая-то ЧПУ поделка на основе шаговиков.
Real Bull mini lathe - мелкий китайский токарник, который переделывают в ЧПУ.
По-моему речь про электронную гитару Олега А., тема у нас на форуме
 ELS = Electronic lead screw - общее название «электронных» гитар для токарных станков.
Изменено пользователем -Dmitry-
