Leonov-x
Breakout Board (Помогите разобраться)
Доброго времени суток!
Помогите разобраться с подключением платы: 6 Axis CNC MACH3 Engraving Machine Interface Breakout Board USB PWM Spindle
Возможная модель:A932A
Мои предположения:
Оригинальное описание платы:
Usage:
The CNC control board is designed for MACH3 software used in computer with line print terminal.The CNC control board is extensively used in the CNC machining,such as: CNC engraving machine,CNC lathes,
CNC Plasma cutting machine,CNC laser engraving machine,CNC milling machine,CNC Machining center and so on.It can be the most cost-effective method using the CNC control board with mach3 software in the computer.
Features:
1. High integration;high reliability
2.Absolute voltage isolation. The CNC control board is powered by computer USB port used as digital power that disgned as common cathode and common ancode
which is connecticed to motor dirver’s common port,and another power is DC 12V to DC 24V which is used as analog power.It’s much more safe and stable by isolating the digital power from analog power.
3.Five signal ports are isolated by optocouplers which can be used as limitting position,finding origin points,starting and Estopping. There is no interruption with isolation of optocouplers.
4.Twelve output ports can control six motors simultaneously,and they are also can be used for some ports as you like.Some ports are communally designed for two functions,choice should be made if you
want to use them.
5.Three relays are put on the board that can be programmed in the mach3 software,and there are three leds used for pilot lamp.The relays can be used to control external equipments such as solenoid valve, cooling pump and so on.
6.Programmed analog voltage from zero to ten volt can be set.The analog voltage can control the speed of spindle motor.
7. The CNC control board can control step motor diver with common cathode or common anode.It also can control servo motor with digital signal.
8.The analog power can be from nine volt to thrity volt.
Вот собственно в чем вопросы:
1. Зачем нужны джамперы (?1, ?2)?
2. К выходам подключаю Step+ и Dir+, а куда правильно подключать Step- и Dir-? (Подключать в ?5 и ?7)
3. На шаговом двигателе (Wantai dq542ma) есть вход ENBL+(+5V) для разрешения работы шд, куда подключать его?
4. Что за земля ?3 и ?4?
Заранее спасибо за помощь.
P.S. Строго не ругайте, совсем новичок.
Изменено пользователем Leonov-x
Не на шаговом двигателе, а на драйвере.
на GND
на GND
Спасибо с этим разобрался.
Но как быть с остальным и плюс еще возник вопрос:
2. К выходам подключаю Step+ и Dir+, а куда правильно подключать Step- и Dir-? (Подключать в ?5 и ?7) (на GND - ?4)
3. На драйвере шаговом двигателе (Wantai dq542ma) есть вход ENBL+(+5V) для разрешения работы шд, куда подключать его?
4. Что за земля ?3 и ?4? GND ?4 - для выходов, GND ?3 - для ШИМ
5. Есть две пары "Common anode DC5V"(?6, ?8) и "Common cathode"(?5, ?7), для каких целей они
Все разобрался.
Джампер 1 переключает что работает выход или ШИМ.
Джамперы 2 Переключение выходы либо реле.
Про "Common anode DC5V" и "Common cathode" :
так как это "обычаня" плата без оптики на выход - это или "общий +5в", или общая "земля" - зависит от того, к чему вы будете подключать и каким сигналом(высокого или низкого уровня) будете рулить драйверами.
Leonov-x, доброго времени суток! Купил себе такую же плату. Не могу теперь ее заставить работать в Mach3. Нет ли у Вас случаем инструкции для настройки этой платы? Или может у кого другого есть? Заранее спасибо...
